Date/Time: Wed, 27 Nov 2024 20:48:34 +0000
Adding tick size to under bars
View Count: 453
[2023-07-04 22:56:03] |
stevenp - Posts: 6 |
I'm trying to figure out how to add Tick Size under bars similar to what Bar Numbering looks like but with the bar size (in ticks) under the bar. Is there a way to do this?
Date Time Of Last Edit: 2023-07-04 22:56:32
Screenshot 2023-07-04 at 6.50.38 PM.png / V - Attached On 2023-07-04 22:50:48 UTC - Size: 21.65 KB - 92 views |
[2023-07-05 13:25:18] |
John - SC Support - Posts: 36344 |
Since you want the range in ticks, you could use a combination of studies, or just use the "Spreadsheet Formula" with the following formula, to get the range: =(H - L)/TICKSIZE Then use the "Study Subgraph Above/Below Bar as Text" study to put that data below the bar. Refer to the following: Spreadsheet Formula Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-06 02:19:03] |
That is exactly what I wanted. Thank you.
Screenshot 2023-07-05 at 10.18.16 PM.png / V - Attached On 2023-07-06 02:18:36 UTC - Size: 10.46 KB - 78 views |
