Date/Time: Wed, 27 Nov 2024 20:33:33 +0000
[Locked] - Trade copier working weird on second account
View Count: 401
[2023-07-04 19:17:49] |
stevenp - Posts: 6 |
Hello, I'm testing out the trade copier in replay mode and I have a Sim1 and Sim2 account set up. If I create a market buy on sim1 (lead account) let's say at 4415 on the ES , then sim2 shows it's in a position at 4490 (the current price of the live market). If I create a limit buy order the second account (sim2) never gets triggered even though the first one does. It's as if the second account isn't using replay data but live data although the chart is showing the same thing on both as far as data goes. Any ideas what i could be doing wrong? Thanks in advance! |
[2023-07-04 19:46:32] |
Just read this: Order Allocation to Trade Accounts cannot be used with the Back Testing functionality. It will not function properly and the orders allocated to the other accounts would always be entered and filled based upon the current price and time.
Seems like the only way to test this is with sim accounts during live session hours. |
[2023-07-04 20:37:01] |
Sierra_Chart Engineering - Posts: 17198 |
Yes!
[2023-07-04 21:34:18] |
Would be a nice feature to have and be able to back test with that though
[2023-07-04 22:42:15] |
That will never come under any circumstances. Do not even think it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-04 22:42:25
[2023-07-04 22:46:11] |
I'm..... I'm thinking it 😳
