Date/Time: Wed, 27 Nov 2024 16:43:54 +0000
[Programming Help] - brick size
View Count: 332
[2023-07-04 16:18:00]
WeroTrader - Posts: 46
Greetings, Sierra Chart team.
I ask for your help to solve two doubts that I have.
1) Which ACSIL code function can return me the brick size of the current chart?
2) Is there a reference study I can use to find out how I can change the brick size on a Renko chart?
I'm not looking for a specific code, I'm just asking for a guide so I can study the documentation.
I thank you for your answer and I remain attentive to it.
[2023-07-05 13:14:25]
John - SC Support - Posts: 36322
The main references for ACSIL are the following (Variables and Functions):
ACSIL Interface Members - Variables and Arrays
https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html
There other sections for more specific items like trading or using buttons. You will find all the sections for the ACSIL documentation at the following link:
Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL))
[2023-07-05 15:05:31]
Sierra_Chart Engineering - Posts: 17195
1, 2. These are the functions you need:
sc.GetBarPeriodParameters()
sc.SetBarPeriodParameters()
[2023-07-19 02:52:44]
Thanks for the responses, they have been very helpful
I have made this function for an automatic trading system:
void ChangeBrick(SCStudyGraphRef sc, int CurrentBrick, int ChgBrick)
if (CurrentBrick != ChgBrick)
n_ACSIL::s_BarPeriod NewBarPeriod;
NewBarPeriod.IntradayChartBarPeriodParameter1 = ChgBrick;
//Set the bar period parameters. This will go into effect after the study function returns.
sc.SetBarPeriodParameters(NewBarPeriod);
The problem is that when I call it, it keeps resizing the brick over and over again like an infinite loop.
Could you give me some reference or explanation of the problem?
NOTE: The function is called from another code, which has in its structure several "return;" and i think this could be the cause of the problem
