Date/Time: Wed, 27 Nov 2024 20:37:26 +0000
Cannot download dll needed
View Count: 476
[2023-07-03 22:39:15]
User200390 - Posts: 31
TicinoTrader says I should have his dll downloaded automatically. It is not downloading.
Seeing this on startup in the log. I cannot find a setting for this.
Error getting list of user files to download. Response: ERROR: Downloading of files on startup is disabled. | HTTP status: Request completed with the HTTP response status code 200. | 2023-07-03 16:56:01.564
TicinoTrader says my "account is probably restricted"
[2023-07-03 23:17:15]
Sierra_Chart Engineering - Posts: 17198
We have enabled file downloads on start up for your Sierra Chart account.
Restart Sierra Chart.
[2023-07-04 01:53:06]
Thanks it downloaded the ticino file but also all of the M2M files and now it hangs when opening the m2m chartbook. Can you disable the file download again until I can work out with Kim Hemmes why this broke. I will roll back the install directory to a prior snapshot.
[2023-07-05 10:13:36]
Yes we can do that but the best thing for you to do right now is to enable Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
This is the way to solve the problem from your side immediately.
[2023-07-05 12:54:10]
Thanks, I rolled back the directory and marked all the m2m dlls as read only and the log threw an error when trying to update them so that is the workaround I have for now many thanks.
