Date/Time: Mon, 14 Sep 2026 21:52:43 +0000
Timestamp errors with exporting and editing, then importing and loading intraday data
View Count: 1339
| [2014-07-04 03:50:24] |
| rc7rader - Posts: 145 |
The US stock exchanges closed at 1:00pm today so the charts have lots of data plotted with dashes. With SierraChart version 1109 and prior, I edited the charts to remove data after 1:00pm to clean up the chart. My procedure is Edit, Export and Edit Intraday Data, then highlight and delete the data 1:00pm and beyond but I leave the last line so Sierrachart can start update from that date and time. Saved the file then, Edit, Import and Load Intraday Data. I did the same procedure today with version 1156 but when I imported and loaded the edited intraday data, I get out of order timestamp errors. To check the data that was imported, I exported the intraday data and saw that the last 10 lines before the last line were overwritten with data causing timestamp errors. I tried the same procedure with 2 other stocks and had the same problem. Please advise. Date Time Of Last Edit: 2014-07-04 03:51:55
| [2014-07-04 05:50:17] |
We are checking on this now.
| [2014-07-05 01:23:07] |
We got sidetracked when we were looking into this, we are going to be working on it in the evening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-05 03:25:04
| [2014-07-05 02:33:05] |
This problem has been resolved. Download 1157 by selecting Help >> Download Current Version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-05 02:33:14
| [2014-07-05 02:55:12] |
Chart looks okay after the import but I'm getting this error message. Software version: 1157 | 2014-07-04 22:46:34 Usage end date: 2015-04-27 | 2014-07-04 22:46:34 Enabled for: Advanced Features. | 2014-07-04 22:46:34 Enabled for: Sierra Chart Historical Data Service. | 2014-07-04 22:46:34 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-07-04 22:46:34 Active service: Interactive Brokers | 2014-07-04 22:46:34 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-07-04 22:46:34 2014-07-05 12:46:34 Local computer clock time | 2014-07-04 22:46:34 2014-07-05 02:46:34 GMT time | 2014-07-04 22:46:34 2014-07-04 22:46:34 Time zone adjusted time | 2014-07-04 22:46:34 Time difference to server time: 3 seconds. | 2014-07-04 22:46:34 Program path: D:\SierraChart\ | 2014-07-04 22:46:34 Data Files path: D:\SierraChart\Data\ | 2014-07-04 22:46:34 OS Version Number: 6.2 | 2014-07-04 22:46:34 Checking for new symbol settings for ib | 2014-07-04 22:46:34 Requesting symbol settings for ib. Overwrite = off. | 2014-07-04 22:46:35 Symbol settings received. | 2014-07-04 22:46:37 Processed received symbol settings | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 11:45:00. Next Bar Date Time: 2014-06-26 11:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 12:45:00. Next Bar Date Time: 2014-06-26 12:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 13:45:00. Next Bar Date Time: 2014-06-26 13:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 14:45:00. Next Bar Date Time: 2014-06-26 14:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 09:45:00. Next Bar Date Time: 2014-06-23 09:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 15:45:00. Next Bar Date Time: 2014-06-26 15:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 10:45:00. Next Bar Date Time: 2014-06-23 10:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 11:45:00. Next Bar Date Time: 2014-06-23 11:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 07:45:00. Next Bar Date Time: 2014-06-27 07:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 12:45:00. Next Bar Date Time: 2014-06-23 12:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 08:45:00. Next Bar Date Time: 2014-06-27 08:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 13:45:00. Next Bar Date Time: 2014-06-23 13:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 09:45:00. Next Bar Date Time: 2014-06-27 09:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 14:45:00. Next Bar Date Time: 2014-06-23 14:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 10:45:00. Next Bar Date Time: 2014-06-27 10:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 15:45:00. Next Bar Date Time: 2014-06-23 15:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 11:45:00. Next Bar Date Time: 2014-06-27 11:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 09:45:00. Next Bar Date Time: 2014-06-24 09:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 12:45:00. Next Bar Date Time: 2014-06-27 12:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 10:45:00. Next Bar Date Time: 2014-06-24 10:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 13:45:00. Next Bar Date Time: 2014-06-27 13:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 11:45:00. Next Bar Date Time: 2014-06-24 11:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 14:45:00. Next Bar Date Time: 2014-06-27 14:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 12:45:00. Next Bar Date Time: 2014-06-24 12:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-27 15:45:00. Next Bar Date Time: 2014-06-27 15:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 13:45:00. Next Bar Date Time: 2014-06-24 13:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 14:45:00. Next Bar Date Time: 2014-06-24 14:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-30 07:45:00. Next Bar Date Time: 2014-06-30 07:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 15:45:00. Next Bar Date Time: 2014-06-24 15:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 09:45:00. Next Bar Date Time: 2014-06-25 09:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-30 08:45:00. Next Bar Date Time: 2014-06-30 08:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 10:45:00. Next Bar Date Time: 2014-06-25 10:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-30 09:45:00. Next Bar Date Time: 2014-06-30 09:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 11:45:00. Next Bar Date Time: 2014-06-25 11:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-30 10:45:00. Next Bar Date Time: 2014-06-30 10:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 12:45:00. Next Bar Date Time: 2014-06-25 12:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-30 11:45:00. Next Bar Date Time: 2014-06-30 11:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 13:45:00. Next Bar Date Time: 2014-06-25 13:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-30 12:45:00. Next Bar Date Time: 2014-06-30 12:10:00. Filename: D:\SierraChart\Data\GPRO.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 14:45:00. Next Bar Date Time: 2014-06-25 14:10:00. Filename: D:\SierraChart\Data\VMW.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 10:45:00. Next Bar Date Time: 2014-06-23 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 11:45:00. Next Bar Date Time: 2014-06-23 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 12:45:00. Next Bar Date Time: 2014-06-23 12:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 13:45:00. Next Bar Date Time: 2014-06-23 13:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 14:45:00. Next Bar Date Time: 2014-06-23 14:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 15:45:00. Next Bar Date Time: 2014-06-23 15:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 10:45:00. Next Bar Date Time: 2014-06-24 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 11:45:00. Next Bar Date Time: 2014-06-24 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 12:45:00. Next Bar Date Time: 2014-06-24 12:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 13:45:00. Next Bar Date Time: 2014-06-24 13:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 14:45:00. Next Bar Date Time: 2014-06-24 14:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 15:45:00. Next Bar Date Time: 2014-06-24 15:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 10:45:00. Next Bar Date Time: 2014-06-25 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 11:45:00. Next Bar Date Time: 2014-06-25 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 12:45:00. Next Bar Date Time: 2014-06-25 12:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 13:45:00. Next Bar Date Time: 2014-06-25 13:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 14:45:00. Next Bar Date Time: 2014-06-25 14:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 15:45:00. Next Bar Date Time: 2014-06-25 15:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 10:45:00. Next Bar Date Time: 2014-06-26 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 11:45:00. Next Bar Date Time: 2014-06-26 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:46:37 Beginning import of data from file: D:\SierraChart\Data\Export\CREE.txt | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 10:45:00. Next Bar Date Time: 2014-06-23 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 11:45:00. Next Bar Date Time: 2014-06-23 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 12:45:00. Next Bar Date Time: 2014-06-23 12:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 13:45:00. Next Bar Date Time: 2014-06-23 13:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 14:45:00. Next Bar Date Time: 2014-06-23 14:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-23 15:45:00. Next Bar Date Time: 2014-06-23 15:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 10:45:00. Next Bar Date Time: 2014-06-24 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 11:45:00. Next Bar Date Time: 2014-06-24 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 12:45:00. Next Bar Date Time: 2014-06-24 12:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 13:45:00. Next Bar Date Time: 2014-06-24 13:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 14:45:00. Next Bar Date Time: 2014-06-24 14:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-24 15:45:00. Next Bar Date Time: 2014-06-24 15:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 10:45:00. Next Bar Date Time: 2014-06-25 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 11:45:00. Next Bar Date Time: 2014-06-25 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 12:45:00. Next Bar Date Time: 2014-06-25 12:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 13:45:00. Next Bar Date Time: 2014-06-25 13:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 14:45:00. Next Bar Date Time: 2014-06-25 14:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-25 15:45:00. Next Bar Date Time: 2014-06-25 15:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 10:45:00. Next Bar Date Time: 2014-06-26 10:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-06-26 11:45:00. Next Bar Date Time: 2014-06-26 11:10:00. Filename: D:\SierraChart\Data\CREE.scid | 2014-07-04 22:47:31 |
| [2014-07-05 03:00:25] |
You need to re-download the data for any chart that gives you an out of order timestamps error because the timestamps have become affected if you had exported and imported the data. To do that, go to an intraday chart for each symbol and select Edit >>Delete All Data and Download. This only needs to be done once for each symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-05 03:01:41
| [2014-07-05 03:13:35] |
Ok that worked. Thanks. The only complaint is the message log window keeps coming out after every import and I had to close it all the time. I wish the message log window only comes out when there are errors.
| [2014-07-05 03:24:43] |
OK we will fix that.
| [2014-07-05 04:28:42] |
Thank you.
