Date/Time: Wed, 27 Nov 2024 20:35:12 +0000
footprint chart (removing column of numbers)
View Count: 265
[2023-07-03 16:24:02]
Mostafa1679 - Posts: 19
how can i remove this column of numbers (see the attachment)
imageScreenshot (2601).png / V - Attached On 2023-07-03 16:23:58 UTC - Size: 141.41 KB - 78 views
[2023-07-03 21:04:50]
John - SC Support - Posts: 36344
Those are whatever text is defined to be displayed in Column 2. If you do not want to see those numbers then set the "Column 2 Numbers Bars Text" to "No Text". Refer to the following:
Numbers Bars: Column # Numbers Bars Text
