Date/Time: Wed, 27 Nov 2024 20:41:57 +0000
need to combine files
View Count: 256
[2023-07-03 16:12:23] |
CRAIG SCOTT - Posts: 5 |
Hi everyone, thanks in advance for your responsiveness and help. Taking me awhile to understand Sierra, thanks for your patience. With that said...can you assist me please? Im trying to combine 3 different templates into one file. I wanted to add 1- CFS Home, 2- CFS Footprint, and 3- CFS Candlestick into one file. I took the templates from NV's G7Fx course and created new titles for the sections i like. Q# Any chance you can remotely 'snap all these three files together' for me, and have the 'quoteboard linked to all the charts' (so that when I select a symbol they all change in tandem)? Thank you in advance. See attached for context. Much appreciated Date Time Of Last Edit: 2023-07-03 16:13:25
[2023-07-03 16:16:23] |
John - SC Support - Posts: 36344 |
We are not exactly sure what you want to do, but if you are wanting to take charts from different chartbooks and put them together in a single chartbook, then you need to use either the "Chart >> Duplicate Chart to Chartbook" or "Chart >> Duplicate Charts to Chartbook", depending on whether you have multiple charts to copy or not. Refer to the following: Chart Menu: Duplicate Chart To Chartbook (Chart menu) Also refer to the following regarding linking the Quote Board: Getting Quotes: Changing Symbol of a Chart or Trade DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
