Date/Time: Wed, 27 Nov 2024 20:50:26 +0000
Real Time Data
View Count: 326
[2023-07-03 11:27:00] |
User737234 - Posts: 6 |
Hello, My account is labled to Non-Professional and i need real time data with market depth i need SPY and QQQ ETFs, US Stocks what Package should i use? |
[2023-07-03 14:35:53] |
SC Support - Posts: 1895 |
Hi Adar, you would need to be on one of SP10, SP11 or SP12 to activate any of our single stock data feeds: Description of Service Packages and Pricing: Packages For US Single Stocks, we have two types of Data, for Market Depth Data we have Nasdaq TotalView which shows you the Order Book (also called Level II or Market Depth) Data at Nasdaq, which would be the largest of the 19 Stock Trading Venues, however when it comes to Volume Data, Nasdaq TotalView will only show you what is happening at Nasdaq. http://www.nasdaqtrader.com/content/ProductsServices/DataProducts/TotalView/TotalViewFactSheet.pdf For the Aggregated Volume data from the 19 Venues you can use the Consolidated Tape (SIP) Data, again this feed will not show you any Level II (Market Depth Data) but you will see the aggregated Volume Data as well as the National Best Bid and Offer (NBBO). We recommend this feed when using the TPO Feature, or Numbers Bars Feature (sometimes called "the Footprint"), or any Volume focused analysis. Which Real-time stock data would be best for you? |
[2023-07-04 12:05:05] |
i decided to activate the CME for S&P Futures, so i activated CME with Market depth for Non-Professional but it still show a Delayed Chart in the MES,ES Futures
[2023-07-04 14:20:50] |
Good stuff Adar, you need to connect Sierra Chart to your Interactive Brokers Trading Account in order to verify your Non-Professional status, for that please use the connection instructions below: Interactive Brokers Trading Service: Setup Instructions Connecting to your Futures Trading Account is the necessary element here, for more information on why you need to do that please see: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees |
