Date/Time: Wed, 27 Nov 2024 20:28:25 +0000
Non Time Based Chart
View Count: 235
[2023-07-03 05:56:03] |
eaglefutures - Posts: 48 |
Hello support, Please can you direct me to where in ACSIL or what in ACSIL can be used to draw a non-time based chart. I am wanting to overlay different options on each other to calculate a P&L or pay-off diagram. Is there perhaps some existing code somewhere that I can use to modify. Basically would like something where I can define the X Axis to any sequence or interval eg 10,15,20. I looked at the forward curve which does the term structure. Would that be a potential starting point ? And is there a code which is shareable for this or where is it sitting if in the ACS Source Folder ? Kind regards |
[2023-07-03 09:05:53] |
Sierra_Chart Engineering - Posts: 17198 |
Refer to this page: ACSIL Interface - Custom Chart Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
