Date/Time: Wed, 27 Nov 2024 20:29:04 +0000
Display the number of ticks after 1000C
View Count: 257
[2023-07-02 19:56:59] |
ppoignot - Posts: 10 |
Hello, The number of ticks disappears on the DPL line as soon as I exceed $1,000. Do you have a trick so that I can see the ticks again? For example, delete the .00? And, do you know if it's possible to replace the C with a $ sign? Thank you and have a nice evening. |
Private File |
[2023-07-03 09:40:10] |
Sierra_Chart Engineering - Posts: 17198 |
In the next release, there will be a Control Bar special item that will show the Daily Profit Loss that you can add to the Control Bar which will be wide enough to show the full content. No: And, do you know if it's possible to replace the C with a $ sign? These kinds of markers will definitely not be used. Only codes codes like USD or EUR. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-03 09:40:19
