Date/Time: Wed, 27 Nov 2024 21:48:17 +0000
Other Data feed
View Count: 334
[2023-07-01 09:32:06] |
User559724 - Posts: 1 |
can I buy a Sierra Chart license for $46 and have live data with other data service or Rhythmic?
[2023-07-01 19:38:16] |
Sierra_Chart Engineering - Posts: 17198 |
Rithmic is supported. You can find all supported services listed here: Table of Contents | (Supported Data and Trading Services) Other services are not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
