Date/Time: Wed, 27 Nov 2024 00:43:29 +0000
Send/Received Data
View Count: 978
[2014-07-03 19:24:46] |
AC94882 - Posts: 8 |
Hello, Is it possible to send a data buffer to a study? I have a C# module that needs to send data, in order to display it on a SC chart. Do you have a code sample for a study that waits for a message and handle the data? If it possible, than where should i put the structure description (*.h) in the SC folder? Thanks, Ariel |
[2014-07-03 22:19:26] |
One method to do this is to write the data to a file and have the Sierra Chart study read the data from the same file. When writing to the file, make sure it is locked so that the Sierra Chart study will not read it until the write is complete. You should use sc.UpdateAlways in the Sierra Chart study so it is continuously being called. Overall this is the most simplest way of doing this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
