Date/Time: Wed, 27 Nov 2024 21:30:40 +0000
[Programming Help] - ACS Button - Show Hide Manual-loop study issue. Help appreciated.
View Count: 644
[2023-06-30 10:58:22] |
User92573 - Posts: 530 |
Dear Support Board Any help appreciated with the following ACS Button/Study Show/Hide (add/remove) issue using a manual loop. I have a small study that uses s_UseTool Tool (Horizontal Line). It works as expected but I'm having problems turning it on/off, or removing and re-applying via an ACS Button. It works fine when I use the Study Settings Inputs. Ticking the 'Hide Study' is picked up by 'sc.HideStudy' and on my input menu '3 lines below un-commented' it also shows and hides the study as expected. I suspect its related to the manual-loop. I don't want to re-appy it as I have a menu event as a trigger. I just cannot seem to get it to work. I know there are some great programmers out there so any help much appreciated. // Abbreviated code: SCInputRef Input_Show_Hide_Study = sc.Input[7]; SCInputRef Input_ACS_Button = sc.Input[8]; // Manual for efficiency as just using a Horizontal Line. sc.AutoLoop = 0; //Set Defaults Input_Show_Hide_Study.Name = "Show Study"; // I can set this manually via the Study Settings form but also want to use the ACS Button. Input_Show_Hide_Study.SetYesNo(1); Input_ACS_Button.Name = "ACS Button to use"; Input_ACS_Button.SetInt(20); //------------------------------------------------------------------------------------------------- // Do data processing // This uses the setting from the Study Setting form. It is only applied when the "Hide Study" check box is ticked. if (sc.HideStudy) return; // These 3 lines of code allow me to set Show Hide from my Setting Inputs. Commented out while I try and do the same from the ACS Buttons. // if(Input_Show_Hide_Study.GetYesNo() == 0) // { // return; // } //------------------------------------------------------------------------------------------------- // ACS Button //------------------------------------------------------------------------------------------------- if (sc.LastCallToFunction || sc.HideStudy) { // Set default hover text and button text for 'LastCallToFunction' sc.SetCustomStudyControlBarButtonHoverText(Input_ACS_Button.GetInt(), ""); sc.SetCustomStudyControlBarButtonText(Input_ACS_Button.GetInt(), ""); // Remove menu items when study is removed sc.RemoveACSChartShortcutMenuItem(sc.ChartNumber, Input_ACS_Button.GetInt()); return; } if (sc.IsFullRecalculation) { sc.SetCustomStudyControlBarButtonHoverText(Input_ACS_Button.GetInt(), "Show / Hide Study"); sc.SetCustomStudyControlBarButtonText(Input_ACS_Button.GetInt(), "SHOW/HIDE"); sc.SetCustomStudyControlBarButtonEnable(Input_ACS_Button.GetInt(), 0); } //------------------------------------------------------------------------------------------------- // ACS Buttons - Actions //------------------------------------------------------------------------------------------------- if(sc.MenuEventID == Input_ACS_Button.GetInt()) { if(Input_Show_Hide_Study.GetYesNo() == 1) // Currently Set to Show { Input_Show_Hide_Study.SetYesNo(0); // Swap to Hide/remove } else if(Input_Show_Hide_Study.GetYesNo() == 0) // Currently Set to Hide { Input_Show_Hide_Study.SetYesNo(1); // Swap to Show/apply } // The message log correctly shows the changes on every click as: Show Hide = 1, Show Hide = 0, Show Hide = 1 etc. msg.Format("Show Hide %i",Input_Show_Hide_Study.GetInt()); sc.AddMessageToLog(msg,1); // This now hides the study as the value is the same as if my user input hade be set to 'Input_Show_Hide_Study.SetInt(0)' // and viewing the 'Input_Show_Hide_Study' shows it's value has changed. // But I'm not sure how to just refresh the study as code the below does not complete the 'return' and hence remove the // Line Tool as expected, unless I open and close the studies form. if(Input_Show_Hide_Study.GetYesNo() == 0) { return; } } A little stumped on this so any help appreciated. Possibly misunderstood the method required to show/hide or add/remove a Tool via the ACS Buttons/Menu Event? Many thanks |
[2023-06-30 16:27:10] |
Update: If it helps anyone. This doesn't delete the drawing but it does Hide the .Tool Drawing. // Commented out in the above. //if(Input_Show_Hide_Study.GetYesNo() == 0) //{ // return; //} //Added to 's_UseTool Tool;' if(Input_Show_Hide_Study.GetYesNo() == 0) { Tool.HideDrawing = 1; } else { Tool.HideDrawing = 0; } |
