Date/Time: Wed, 27 Nov 2024 21:30:14 +0000
Export intraday futures' individual contract efficiently
View Count: 262
[2023-06-30 03:18:59] |
User14410 - Posts: 38 |
Hi team, I would like to ask is there a documentation describing how to export intraday futures' individual contract in a efficient manner from Sierra Chart? I am currently trying to export it one by one. Thanks. |
[2023-06-30 13:21:11] |
There is not a way to do the export using the built-in functions other than opening a chart for each one and then selecting the export option. It probably is not worth it, but you could create a custom study to change the symbol and export the data. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
