Date/Time: Wed, 27 Nov 2024 20:52:14 +0000
Market Depth Historical Graph
View Count: 343
[2023-06-30 01:44:19] |
socaltrader - Posts: 11 |
Greetings, I recently subscribed to Denali Level 2 for the entire CME Group However, the Market Depth Historical Graph is not functioning for the NYMEX products |
[2023-06-30 13:18:31] |
John - SC Support - Posts: 36344 |
Please give us 1 symbol for which you are having an issue. Also, do the following on a chart for one of the NYMEX products. - Add the Market Depth Historical Graph, if not already on. - Set the Input for "Show Quantity Numbers" to "In Bars Only". - Set the Input for "Use Secondary Numbers Color for Quantities Greater Than or Equal To" to a value of 1. - Set the Input for "Secondary Numbers Color for Quantities Greater Than or Equal To" a bright color like red or hot pink (depending on your background color - just make sure it is something that will stand out). Then take a screenshot and attach it to this thread. If the Market Depth data is there, the numbers should be showing, even if the coloring for each cell is not obvious. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-01 09:33:59] |
Sierra_Chart Engineering - Posts: 17198 |
Also refer to: Market Depth Historical Graph: Market Depth Historical Graph Not Displaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-06 12:30:19] |
it is resolved... thank you so much for the fast response!
