Date/Time: Wed, 27 Nov 2024 21:32:39 +0000
Range Bars
View Count: 354
[2023-06-29 22:26:58] |
User156504 - Posts: 1 |
I have adjacent charts on a Chartbook (see attached screenshot). The bars on the left chart are candlesticks and those on the right chart are numbers bars. The bars in both charts were loaded as Range Per Bar - Standard (in ticks). However, there are two discrepancies. The menu bar of the left chart correctly lists it as "5.25 Range," but the menu bar of the right chart lists it as "5 Range." The main problem, though, is the numbers bars have 24 levels. Due to the diagonal nature of footprint bars, I would expect to see 22 levels for a range bar set at 21 ticks. Unless there is another setting I'm unaware of, the bars in the right chart should not have 24 levels. Thank you for your assistance. Mike Hesson PS: I don't think I've attached the screenshot correctly, but I think I've fully explained the problem. |
Range Bar Diff..jpg / V - Attached On 2023-06-29 22:19:47 UTC - Size: 177.46 KB - 95 views Attachment Deleted. Private File |
[2023-06-30 11:05:06] |
Sierra_Chart Engineering - Posts: 17198 |
Refer to this page: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Also refer to: Working With Charts: Resolving Differences of Chart Bars Between Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
