Date/Time: Wed, 27 Nov 2024 21:36:58 +0000
Run SC on a second computer
View Count: 246
[2023-06-29 21:31:16] |
User495945 - Posts: 7 |
Is a second computer allowed to run concurrently using same parameters?
[2023-06-29 22:00:20] |
By default, the Sierra Chart accounts allow for 2 computers to run the Sierra Chart software concurrently under the same login. But, the exchanges work a bit differently, so you can only get the data from the Denali Exchange Data Feed to one computer at a time, unless you pay a second exchange fee. Refer to the information here: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
