Date/Time: Wed, 27 Nov 2024 21:51:45 +0000
1 - How do I adjust font & size of Chart trading window & 2 - move Trade marker to right
View Count: 495
[2023-06-29 19:51:58] |
JohnR - User831573 - Posts: 306 |
I have searched in the various Global font 'things', and also Trade Window "M" menu then settings, but nothing there. I also looked in Global as well as all 3 tabs/menu options on the Chart Trade Window. - I want to make the font size in all of the areas of the Chart Trade Window larger. 2 - When a trade is open, there is a marker and lien across my entire chart showing the price level, and other info on that order. I would like to have that on the right of the chart in the "Future Bars" area and I would lock the chart to the needed width. Any guidance / help or pointer to doc, would be much appreciated. JohnR |
SC_Trading_Window_Font.jpg / V - Attached On 2023-06-29 19:50:45 UTC - Size: 104.52 KB - 118 views sc_TradeLevel.jpg / V - Attached On 2023-06-29 19:51:03 UTC - Size: 23.13 KB - 92 views |
[2023-06-29 20:08:13] |
OK, I found how to handle # 2 - on active trades left / right of chart. I could not find it on the Global settings, but on the Chart settings window. Maybe these fields should be added to the global windows, or can you please point me to the correct window / option. Again - thanks for your time, JohnR |
SC_Chart Setting Window.jpg / V - Attached On 2023-06-29 20:07:47 UTC - Size: 335.61 KB - 102 views |
[2023-06-29 21:53:18] |
1. The items on that window can not be changed. We will eventually have a new window that will be more configurable, but we do not have a specific timeframe at this time. 2. This is a per-chart setting, this is why it is under the "Chart Settings" rather than the General Settings or Trade Settings (which are both global settings). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-30 18:28:51] |
John, first thanks for your time to reply. As a quick fix, would it be possible for request #1 - trading window - can it use the same font and size that I set for the chart it is associated with? So, just pick up the font properties from the chart it is tied to. Hope it is not too much effort, JohnR Date Time Of Last Edit: 2023-06-30 18:29:41
[2023-06-30 19:21:01] |
That particular window is very specialized and there is no room to allow for varying fonts. It is what it is at this point. As we said, it will be replaced in the future, which is our solution to this.
