Date/Time: Wed, 27 Nov 2024 21:51:57 +0000
Candle price levels
View Count: 324
[2023-06-29 16:25:56]
Mustang77 - Posts: 122
Hi
How can i see the open, high, low and close of a candle?
i mean is there a way to hover the cursor over the candle and see that info somewhere? rathen than place the cursor and read on the price axis ?
Also, is there a way to add a magnet so when i draw a line or a ray it anchors from the high or low of a candle ?
Thank you
[2023-06-29 18:23:26]
John - SC Support - Posts: 36350
You need to use the "Tool Values Window" to see this. The "Compact Tool Values Window" may be closer to what you want, and there is also a Horizontal option for the "Compact Tool Values Window". Refer to the following:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
Chart Drawing Tools: Snap to High/Low | Snap Side to High/Low
Chart Drawing Tools: Snapping (Global Settings >> Tool Settings >> General)
Date Time Of Last Edit: 2023-06-29 18:27:15
