Date/Time: Wed, 27 Nov 2024 21:30:30 +0000
Trade history on the chart
View Count: 455
[2023-06-28 18:05:17]
Radu Sirbu - Posts: 40
Hi guys,
Is it possible to display on the chart the history of trades on the corresponding bars/candles/rotations same as it is, for example, on Tradervue? - see the screenshot enclosed.
It would help a lot in reviewing the trades at the end of the day. It should not be complicated to display this history.
Thanks,
imageexample.png / V - Attached On 2023-06-28 18:01:43 UTC - Size: 15.23 KB - 91 views
[2023-06-28 18:46:53]
John - SC Support - Posts: 36350
You can display the Order Fills. Refer to the following information:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2023-06-28 19:19:38]
thanks!
[2023-06-29 17:22:16]
I looked at this option, but it doesn't show the exact level where I got IN and OUT.
Not even the result of the trades is correct. It always shows the same result. Also, the text is displayed above and below the candles. I would not be interested in having all that text displayed, but instead, I would be interested in having highlighted the entry and exit level through a small shape (dot, arrow, etc.) inside the candle, without any other text. Is such a thing possible?
[2023-06-29 18:39:43]
The Order Fills show exactly where you got "In" and "Out".
Also, the section we linked you to originally contains all the information you are asking about. In particular, note the following sub-sections:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
Chart Trading and the Chart DOM: Displaying Order Fill Arrows Only
