Date/Time: Wed, 27 Nov 2024 21:46:59 +0000
REWIND TPO CHART
View Count: 223
[2023-06-28 16:57:54] |
Rodnee Pope - Posts: 1 |
How do I pull the TPO back far enought to see previous Tpo's? Changing the Date Range does not work. I can see where I have drawn them in but it wont go back further than the past 12 months.
tpo settings.jpg / V - Attached On 2023-06-28 16:53:02 UTC - Size: 96.12 KB - 68 views |
[2023-06-28 17:20:08] |
The TPOs are only going to be drawn based on the loaded underlying data. The implication from what you are stating is that you only have data loaded going back 12 months. Refer to the following: Loading More Or Less Data into an Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
