Date/Time: Wed, 27 Nov 2024 21:51:35 +0000
closing sierra and all my instances at once
View Count: 344
[2023-06-28 16:08:51]
User194592 - Posts: 7
Good afternoon,
I have my sierra opened with 3 sub instances (therefore 4 windows opened), I cannot find a way to close them all at once, I have to do file/ exit on each of the window. Any suggestion?
Thank you,
Best.
A.
Date Time Of Last Edit: 2023-06-28 16:09:03
[2023-06-28 17:03:02]
JohnR - User831573 - Posts: 306
A possible solution would be to use AutoHotKey or another preferred keyboard macro/mouse program. AHK lets you search for a window by its title bar, then make it active and finally issue the keystrokes to exit the program, repeat for each instance and then do the same for the initial one.
JohnR
[2023-06-28 17:21:39]
John - SC Support - Posts: 36350
There is not a way within Sierra Chart to close multiple instances. Each instance is its own copy of Sierra Chart and therefore they are not connected in a way that this can be done.
