Date/Time: Wed, 27 Nov 2024 21:37:39 +0000
ICEUS Futures Access
View Count: 403
[2023-06-28 14:18:23] |
George P. Theodotou - Posts: 2 |
Hi there, normally I have Service Package 5, not sure does this include ICEUS Futures data? If not, how do I add this? Thanks
[2023-06-28 15:00:05] |
We do not have real-time data for ICE. If you open a chart for the ICE products, you will be able to get historical data. If you need real-time data for ICE, then you will have to see if you can get it from your trading service, or check with IQ Feed. Refer to the following for IQ Feed: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
