Date/Time: Wed, 27 Nov 2024 21:36:49 +0000
Hide study checkbox in the F6/Study Settings dialog is broken in v2516
View Count: 335
[2023-06-27 23:16:43]
User719512 - Posts: 265
I recall some strangeness in v2512 or so, thought you fixed this, and updated to latest build, and the Hide checkbox is broken. Went back to v2504 and the checkbox works as expected.
Repro:
new chart
add a study (like Moving Average Simple)
Hit APPLY
Check HIDE Checkbox
Hit APPLY
-> study does not Hide.
If you go to study settings and change it and hit Ok, then Apply, the Hide applies.
It seems like the first change you make to a study to hide or not hide it, works. Further changes are not working as the dialog appears to have lost the state. You have to close and reopen the dialog again for another change.
Not sure how this would break, but it's really annoying for sure. Hope you can get a fix for this soon!
[2023-06-28 01:33:19]
User264623 - Posts: 28
Using v2514 here and concur with the Hide checkbox and Apply button not working as usual. Same experience as described in post #1.
[2023-06-28 09:29:35]
Sierra_Chart Engineering - Posts: 17198
Regarding post #1 we will look into this.
Regarding post #2, update Sierra Chart to the current version:
[2023-06-28 09:31:24]
Regarding post #1 we also want you to update to the current version:
We cannot reproduce this. There was one change we made, from a user request to eliminate unnecessary calculations if someone pressed Apply, then pressed Ok, when they really should press Cancel, and that is the reason for the problem but that was resolved.
[2023-06-28 10:32:37]
User907968 - Posts: 823
The problem from post #1 still persists.
When hiding/unhiding only the first press of apply (in the chart studies window) has any effect.
Only when an additional change is made (study added/removed/changed) does the button becoms effective again.
Also the hide check box sometimes does not update correctly.
[2023-06-28 11:14:48]
Ok we misunderstood. We were looking at the Hide Study setting on the Study Settings window itself.
