Date/Time: Wed, 27 Nov 2024 21:39:43 +0000
Error/Bug in formatting?
View Count: 252
[2023-06-27 21:39:27] |
User509533 - Posts: 57 |
I got the following error from Sierra Chart. I think the banding value is not '600' but '6.00' for ES. "Teton CME Order Routing (Order reject). Info: CME (Rejected). Text: Order price is outside bands 'Difference between stop and limit price is larger than banding value of 600.0 using Delta .00'. " |
[2023-06-28 08:57:35] |
Sierra_Chart Engineering - Posts: 17198 |
That message comes from the CME and the 600 really represents 6.00. Check the Limit offset: Basic Trading and the Trade Window: Set >> Stop-Limit Order Limit Offset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
