Date/Time: Wed, 27 Nov 2024 00:45:45 +0000
Daily OHLC – single point problem
View Count: 1093
[2014-07-03 07:46:39] |
imdtrader - Posts: 26 |
Hello, I have problem with study Daily OHLC – single point. I get multiple single points for the close. Open works just fine. See included screenshot where I plot just open and close – the lines are from Daily OHLC indicator. Triangles are from Daily OHLC – Single point and Sierra is plotting more closes in one session. The open is correct. I use only one session in the charts. Sierra version 1149. Any tip what can be wrong? Update: I see what the problem is. Sierra is marking every close that is matching daily close in the same day. Not only the last one. Can you please correct this? Thank you. Date Time Of Last Edit: 2014-07-03 07:50:04
[2014-07-03 07:54:51] |
Disregard the prior response which was deleted. This is how the study is designed and it will not change. We are not going to spend time to make it work like you want. That is not easy programming because it is time-based programming and we have far higher priorities. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
