Date/Time: Wed, 27 Nov 2024 21:40:19 +0000
question related to chart replay
View Count: 279
[2023-06-27 17:32:32] |
User887126 - Posts: 66 |
Hi SC team, 1) how can i improve the performance for chart replay? Everytime i skip forward or backward by a few minutes, my charts take a while to reload. I am already using nvme ssd drive. What other things can i do to make the chart replay and loading process faster? 2) Is there a way to see MBO in chart replay? please advise. thank you |
[2023-06-27 21:23:10] |
1) Do not skip forward or backward. Doing so requires a reload of the chart, which, as you have seen, takes time. If you are needing to do the forward/backward skip, then you will want to reduce the number of days to load to the minimum for the replay. 2) The MBO data is not stored, so it is not available during a replay. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-28 09:08:25] |
Sierra_Chart Engineering - Posts: 17198 |
1. Refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
