Date/Time: Wed, 27 Nov 2024 21:27:41 +0000
Volume By Price on Sub Graphs
View Count: 243
[2023-06-27 16:33:20] |
Oz - Posts: 50 |
Hi I'm new to Sierra. Is it possible to implement the Volume By Price study on sub-graphs? Hence I have a multi instrument chart. Main Price Graph = YM Symbol Subgraph chart region 2 = ES Symbol Subgraph Chart Region 3 = NQ Symbol Hence is it possible to add Volume By Price on chart region 2 & 3 Many thankls |
[2023-06-27 16:33:25] |
It can be done, but you have to be careful and the option for Visible Bars will not work. To do this, you need to do the following on the Volume by Price study: - Set "Based On" to the particular graph you want. - Set "Chart Region" to the same region as the above graph. - Set "Volume Graph Period Type" as desired - as mentioned above, Visible Bars will not work. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
