Date/Time: Wed, 27 Nov 2024 21:27:25 +0000
Inverse
View Count: 231
[2023-06-27 14:27:59]
Arcade1953 - Posts: 14
Is there a way to inverse the VOLQ-NQGI so it goes the same way as price and ADR?
[2023-06-27 14:36:54]
John - SC Support - Posts: 36350
You can either select the option for "Invert Prices" on the Chart Settings or use the "Multiply Bars by -1" study. Refer to the following documentation:
Chart Settings: Invert Prices (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Multiply Bars By -1
