Date/Time: Wed, 27 Nov 2024 21:28:44 +0000
Order Allocation with 17 charts and 3 APEX accounts makes Sierra crash
View Count: 366
[2023-06-27 10:37:08] |
User395685 - Posts: 33 |
Hi, I have 3 Apex accounts. I am trying to set up the order allocation to copy trades between accounts. I have a chartbook with 17 charts (17 different markets). It worked with the first chart (trades are copied between accounts), but as soon as I try to set up a second chart, Sierra crashes, within the order allocation window or shortly after I click OK. I tried about 10 times, same result each time. I am using version 2514. Thanks for your help. Date Time Of Last Edit: 2023-06-27 10:37:38
[2023-06-27 11:08:03] |
Sierra_Chart Engineering - Posts: 17198 |
Are you running Sierra Chart on Wine? We have heard of this problem when using Wine.
[2023-06-27 11:47:00] |
I am running it on Windows 7 64 bits.
Date Time Of Last Edit: 2023-06-27 12:02:51
[2023-06-27 12:55:24] |
We are checking on this.
[2023-06-27 14:22:42] |
We found the problem. We will have this resolved in the next release coming out this evening.
[2023-06-27 15:30:53] |
Ok, I will check tomorrow if this works.
[2023-06-29 08:46:44] |
It seems to work with no crash now. Thanks.
[2023-06-29 10:06:20] |
Yes definitely this is resolved.
