Date/Time: Wed, 27 Nov 2024 21:35:34 +0000
Order rejection due to negative price?
View Count: 294
[2023-06-27 07:24:49] |
User146848 - Posts: 121 |
Greetings, had the same issue yesterday with CADUSD. (same EURUSD chartbook...just changed the symbol). Whats going on? Order update (Order reject). Info: Teton CME Order Routing (Order reject). Info: CME (Rejected). Text: Price must be greater than zero 'Order for id: M6EU3 has non-positive price -23.9016'. Text: Attached order. Parent: 10517. Tag: Attached order. Parent: 4494. Text: Attached order. Parent: 4494. Internal Order ID: 4496. Service Order ID: 10519. Symbol: M6EU23_FUT_CME. 2023-06-27 09:14:32.152 |
[2023-06-27 10:43:44] |
Sierra_Chart Engineering - Posts: 17198 |
This is out of context. We do not know any of the surrounding details. The first thing is to open a chart directly for that symbol and not use the Trade And Current Quote Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-27 10:49:02
[2023-06-27 16:12:03] |
Trading the micro as trade only symbol results in a rejected order. Trading the currency micro as quote symbol works just fine. Updating the symbol didnt change anything. |
[2023-06-27 18:30:14] |
Refer to: Sierra Chart Teton Futures Order Routing: Using Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
