Date/Time: Wed, 27 Nov 2024 21:48:17 +0000
Notepad++ Editor does not start
View Count: 271
[2023-06-26 22:58:34] |
User1967 - Posts: 34 |
Hello, I am trying to write a custom study and open C++ Notepad++ Editor from Analysis -> New/Open Custom Study File as described in the documentation. the dialogue opens but once you type the name or select an existing Custom Study then nothing happens ... Please advise ...
[2023-06-27 13:52:19] |
Check your setting for the "Text Editor Path and Filename" and ensure the file is there. Refer to the following: General Settings Window: Text Editor Path and Filename (Global Settings >> General Settings >> Paths >> Files and Folder Paths) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
