Date/Time: Wed, 27 Nov 2024 21:47:17 +0000
Order allocation
View Count: 307
[2023-06-26 21:46:46]
User987069 - Posts: 45
Hey, is there a limit to how many accounts i can allocate a trade to?
Example: If i have 25 accounts available under ONE username/ login, can trades be allocated to all 25 accounts
[2023-06-27 13:49:22]
John - SC Support - Posts: 36350
There is not a limit on the number of accounts that can be assigned.
[2023-06-27 14:31:17]
So only up to three live accounts can be associated to the same Rithmic ID (credentials). If more than three live accounts are received, they will be assigned to a new Rithmic ID. But regardless, all of the live accounts/ Rithmic ID's will be associated to the same UProfit credentials.
Would I be able to allocate trades across all of the live accounts associated to the UPT username? Or would it only be the 3 associated to a particular Rithmic ID?
[2023-06-27 14:38:35]
We do not know, as this is a Rithmic issue. From our perspective, as long as you can access the accounts under the "Order Allocation to Trade Accounts", then those accounts should receive the copied orders. But you should do a trial to ensure that it is working properly given the Rithmic limitations you mention.
