Date/Time: Wed, 27 Nov 2024 22:32:10 +0000
DOM speed is slow
View Count: 665
[2023-06-26 18:12:12]
DoubleM - Posts: 6
Hello, I have followed all of the instructions to make my DOM print speed faster but it is still slow. I am using the Denali exchange feed with level two depth of market.
Below is a video of a DOM of one person who seems to make work but everything I try does not seem to produce the same results. I have gone through the instructions and here on the support forums but nothing is working or I am not doing something in the correct sequence.
below is a video on what I would like to replicate and how my system is not working to the degree I wish.
https://youtu.be/Vppm41t54gA
[2023-06-26 19:09:31]
Sierra_Chart Engineering - Posts: 17198
Did you follow the instructions here:
Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM
First step is to make sure you just have only one Chart or Trading DOM open in the entire instance of Sierra Chart. You can add more later, but only after you get the performance the way you need.
Date Time Of Last Edit: 2023-06-26 19:10:04
