Date/Time: Wed, 27 Nov 2024 22:46:57 +0000
options differ in UI vs ACSIL - which is correct? + need to complete last line in ACSIL
View Count: 254
[2023-06-26 13:59:00]
JohnR - User831573 - Posts: 306
I want to start working with UseToolConfigNum, It states config # 1 - 8, but the UI has 1 - 24 I can set as custom configs. Shouldn't they be the same?
Also - I think SC needs to add the link / info at the end of the sentence below -> for additional information, refer to . refer to what? Probably, good stuff for us new to the area.
s_UseTool::UseToolConfigNum Type: Integer
This can be set to 1 through 8. This specifies the particular tool configuration defined for the chart drawing tool specified, to automatically be applied to the chart drawing being added. for additional information, refer to .
Thanks for your time,
JohnR
Date Time Of Last Edit: 2023-06-26 14:03:46
[2023-06-26 14:22:15]
Sierra_Chart Engineering - Posts: 17198
You can use up to 24. And we are updating the documentation now.
