Date/Time: Wed, 27 Nov 2024 22:49:29 +0000
chartbook notcompatibile
View Count: 277
[2023-06-26 12:52:05] |
User159452 - Posts: 2 |
hi please convert my chartbook is not compatibile . thank you milosz |
G7FXFOUNDATIONDOMCHARTBOOK-200330-085855 (1).Cht - Attached On 2023-06-26 12:51:28 UTC - Size: 276.18 KB - 88 views Attachment Deleted. |
[2023-06-26 19:05:28] |
You need to get an updated chart book from G7FX.
[2023-06-27 07:52:43] |
Sierra_Chart Engineering - Posts: 17198 |
Also refer to: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
