Date/Time: Wed, 27 Nov 2024 22:38:02 +0000
LIFFE FTSE-100 FUTURES DATA
View Count: 407
[2023-06-26 10:51:49] |
Stav - Posts: 104 |
Hi John, Sierra Chart, I'm trying to access LIFFE FTSE-100 futures using the Sep(ZU23-LIFFE) and Dec(ZZ23-LIFFE) contracts. I've set the intraday session start time as 08:00:00 & end time as 16:30:00 and the time zone settings to London (+0 GMT/1BST) in Chart Settings and in Global Settings. I'm not getting any updates, not sure why could it be my symbols are not correct, I cannot find these code within Euronext, maybe they have moved over to a different exchange? I cannot find them on the ICE? Any help would be very much appreciated. Many thanks Stephen |
[2023-06-26 11:33:31] |
Sierra_Chart Engineering - Posts: 17198 |
This data is end of day delayed. You will not receive any real time or delayed data. At the end of the day you can update the chart with Edit >>Download Data from End of Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-26 11:33:46
[2023-06-26 11:46:14] |
Stav - Posts: 104 |
Hi, Okay, understood. Many thanks. Kind Regards Stephen |
