Date/Time: Wed, 27 Nov 2024 00:21:07 +0000
How could I get a tick chart
View Count: 978
[2014-07-03 00:34:58] |
User83601 - Posts: 8 |
Please tell me how could I get a tick chart like the attached file.
[2014-07-03 01:09:47] |
By tick chart we assume you mean a chart that has bars based upon a certain number of trades per bar. This is set through Chart >> Chart Settings. For instructions to do this, refer to this section here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-03 01:41:28] |
Thank you. could I set bid and ask tick chart in one chart? |
[2014-07-03 03:26:30] |
In the case of a Forex chart, if you want to chart based on bid prices and/or ask prices you need to use one of the data recording suffixes which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_RecordingModes.php This page also explains how to chart both the bid price and the ask price in one chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-03 05:06:09] |
Thank you. but the distance between bid and ask are so wide. could they merge in one chart just like my attached file? |
[2014-07-04 06:57:24] |
We updated the documentation for this to explain just how to do this: https://www.sierrachart.com/index.php?page=doc/doc_RecordingModes.php#ChartingBidAsk After going to that section be sure to reload the page to get the latest content. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-04 07:58:41] |
Thank you. It is ok now. Date Time Of Last Edit: 2014-07-04 08:00:31
