Date/Time: Wed, 27 Nov 2024 22:49:56 +0000
Market depth events from ASCIL
View Count: 304
[2023-06-26 10:43:38]
B - Posts: 2
Hi there, as I read from the support board, getting realtime data from DTC server is no longer supported due to exchange rules. Is there any way to access a list of updates to the order book through ASCIL? I'm currently looping through the price/quantity at each level but I find that it doesn't provide me with enough temporal resolution.
Any advice would be greatly appreciated. Thanks!
[2023-06-26 13:41:44]
Sierra_Chart Engineering - Posts: 17198
The only thing we can think of is for you to read the market depth data files directly. Here is the file format:
Market Depth Data File Format
[2023-06-26 13:53:01]
B - Posts: 2
Is there a way to configure SierraChart to write to the marketdepth data file as soon as new events are received?
[2023-06-26 13:55:30]
Yes, there is a way to control this but it might not be user accessible. We will check on that.
[2023-06-26 14:17:01]
This is controllable through Global Settings >> Advanced Settings >> Other >> Intraday File Flush Time in Milliseconds.
We really would not recommend using a number less than 100 and that is getting quite low.
