Date/Time: Wed, 27 Nov 2024 22:24:47 +0000
TPOs displaying strange lines
View Count: 229
[2023-06-26 07:28:54]
Tofer - Posts: 38
Hello team,
Im currently have the situation displayed on the image, so it is impossible for me to read the TPO correctly. What I did is to Duplicate All Charts to Chartbook, I selected "Switch to new Chartbook" and "Create new Chartbook". Then I changed the symbol on the new Chartbook, not sure if this helps, but the original Chartbook was the ES, and the new one is the NQ.
After that the old chartbook displays the lines I mentioned. I tried closing and opening again, even the whole Sierra, same situation. Any tips?
Thank you very much!
imageScreenshot 2023-06-26 091436.png / V - Attached On 2023-06-26 07:18:24 UTC - Size: 248.65 KB - 62 views
[2023-06-26 07:35:14]
Sierra_Chart Engineering - Posts: 17198
You need to remove all studies from that chart, except the TPO Profile Chart study and see which one is causing this.
Refer to:
Chart Studies
[2023-06-26 09:04:52]
Tofer - Posts: 38
thanks for the quick response, so the problem was with with Overlay studies, all of them were linked to the wrong charts. Is there a way to solve that when duplicating a chart? luckily I did not have so many Overlay studies, but it was a bit annoying to go one by one and check which one should be the referenced chart.
Thank you!
[2023-06-26 09:36:40]
No there is no way to automatically solve this. You need to manually update the Inputs for those studies.
