Date/Time: Tue, 26 Nov 2024 06:36:47 +0000
How to maintain multiple OCO's orders at the same time
View Count: 856
[2023-06-26 01:36:02]
andreaslovesstocks - Posts: 11
I want to be able to put on multiple OCO order with different entry targets - Example -OCO 1: Short 2 Contract at price 4404 - Target: 4400 - Stop: 4406 OCO 2: Short 2 Contracts at price 4420 - Target 4415 - Stop: 4422.
Issue is....as soon as ''OCO 1 gets executed - meaning filled'' - the other OCO is deleted. I would want to have to OCO orders active. So as soon as I reach my target for OCO 1 ...OCO 2 should still be active waiting for a 2 contract fill at 4420
Hope this makes sense.
Thank you.
imageoco.jpg / V - Attached On 2023-06-26 01:35:37 UTC - Size: 636.52 KB - 155 views
[2023-06-26 07:55:40]
Sierra_Chart Engineering - Posts: 17179
This does not make sense to us and is not clear.
These two bracket order sets that you have, are completely independent of each other.
[2023-06-26 10:52:16]
351616 - Posts: 4
Just trying to be helpful...This could be the problem. Go to the trading menu panel "M" from the attach trade window to chart. Go to "Orders" tab. Go to the bottom and make sure that this has no checkmark next to it "Cancel Orders on Flat Postion"
[2023-06-26 14:04:23]
Hi there,
Thanks @351616 - that was the issue. Small but significant checkmark.
Thanks! Appreciate the help.
Solved
[2023-07-10 13:21:40]
I have to add to this ticket - Unfortunately this is NOT solved.
Issue is the following - I would like to have the Following OCO's in Place
1.
Buy at 4414
Limit sell at 4421
Stop 4410
2. Buy at 4453
Limit sell at 4463
Stop at 4450
The issue here is - I can set both OCO's - so 1. and 2.
but unfortunately as soon as the 1. OCO is filled - in this case
1.
Buy at 4414
Limit sell at 4421
Stop 4410
The 2nd OCO - gets automatically deleted
Goal is to keep also the 2nd OCO active
[2023-07-10 15:54:00]
John - SC Support - Posts: 36286
The scenario you describe is not making sense to us. What kind of orders are the main parent orders?
They can not be Market Orders, or the first set would be closed out before the second could ever occur, as the Target would be hit at 4421, but the main order for the second group is at 4453.
[2023-12-27 05:15:30]
Hello - I tried a lot since my last post here but still not able to create what I want to create.
The goal is to have two different entry points for 2 Different OCO entry points
See attached example:
1. OCO Group
Limit BUY (LONG) at 4815 (Parent order)
Limit SELL at 4820 (Child)
STOP at 4812 (Child)
2. OCO Group
Limit BUY (LONG) at 4810 (Parent order)
Limit SELL at 4815 (Child)
STOP at 4807 (Child)
NON! Of the above orders is filled yet - goal is to have both active (which works) - but in the scenario the first order successfully executed (Sell) at 4820 - OR STOP at 4812....
I want the 2. OCO Group order! to ALWAYS stay active. Meaning if - 1. OCO Group is done and executed - 2. OCO group should stay active
