Date/Time: Wed, 27 Nov 2024 21:34:24 +0000
Sim 1 trades appear on non-sim Trade activity and cannot be cleared
View Count: 288
[2023-06-25 14:53:28] |
User589284 - Posts: 6 |
Hi. (I tried to search previous issues as this on the support board but could not find). I have 3 Simulated instances. For some reason I do not understand, on Instance #2, I have a trade log of Non-sim under the Sim1 account. Given it is a Non-sim search, it seems I cannot erase it. But I am also worried because I cannot understand how this could have occurred. And that it may affect future Sim results. I do not have this data on the other instances. I attach a screenshot of the Trade activity monitor. Please let me know how can I erase it and prevent such for the future. Thank you |
Attachment Deleted. Screenshot 2023-06-25 154822.png / V - Attached On 2023-06-25 14:50:55 UTC - Size: 67.41 KB - 67 views |
[2023-06-26 07:49:24] |
Sierra_Chart Engineering - Posts: 17198 |
In a sub instance, with Trade Simulation Mode disabled, this will be the case: , I have a trade log of Non-sim under the Sim1 account.
The trading activity is considered non-simulated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-26 07:49:37
[2023-06-27 14:27:01] |
So in that case, I guess the trade activity on the non-simulated mode cannot be erased. Anyway, I erased the instance itself and will create a new one. Thank you Date Time Of Last Edit: 2023-06-27 14:27:36
[2023-06-27 18:29:49] |
You can delete this trading activity through the main instance of Sierra Chart: Trade Activity Log: Clearing Trade Activity Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
