Date/Time: Wed, 27 Nov 2024 00:33:27 +0000
Missing Data on Weekly VP
View Count: 350
[2023-06-25 01:58:55] |
Sergio Hernandez - Posts: 23 |
My weekly volume profiles have gaps. Appears to only affect the weekly chart. Any guidance on resolution would be appreciated. Thanks! Best, Sergio |
SC-Support-VP.png / V - Attached On 2023-06-25 01:55:19 UTC - Size: 32.64 KB - 92 views |
[2023-06-26 07:57:50] |
Sierra_Chart Engineering - Posts: 17187 |
We do not know what symbol that is for. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Also refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-26 07:58:03
[2023-10-08 20:29:21] |
Fixed. Thanks, SC support
