Date/Time: Wed, 27 Nov 2024 22:49:46 +0000
Replay for Daily and above charts
View Count: 294
[2023-06-24 09:55:47] |
al-right - Posts: 30 |
Replaying intraday charts works fine but if I change the TF to Daily or above, the chart resets to the current time. How can I fix that? Thank you
[2023-06-24 10:01:18] |
Sierra_Chart Engineering - Posts: 17198 |
Refer to: Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-24 14:38:59] |
Refer to:
Thanks for your reply but that doesn't seem to solve the problem, which I will re-phrase as maybe I wasn't clear enough. While in replay mode, for instance on a 15 min chart, I can change the TF on-the-fly up until 4H, but if I click Daily or above, the chart stops replaying and resets to the current time. What I mean is, while I'm replaying an intraday TF I would like to switch the chart to higher TFs (above intraday) to see past S/R levels.
Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts |
[2023-06-24 15:06:12] |
You cannot do what you are doing. It is not supported. The behavior that you see is expected.
