Date/Time: Wed, 27 Nov 2024 22:38:56 +0000
UNABLE TO FIND CHARTBOOKEXAMPLE.CHT BY DEFAULT
View Count: 243
[2023-06-23 16:29:12] |
User806679 - Posts: 1 |
Hello, I have recently downloaded Sierra chat onto my laptop however, i only have examplechartbook.cht downloaded when i believe i am meant to also have chartbookexample.cht as well. Can you let me know if this is an error or am i only meant to have the one ? |
[2023-06-23 19:23:55] |
Sierra_Chart Engineering - Posts: 17198 |
There should only one example Chartbook that Sierra Chart is provided by default. Here is information about Chartbooks: Chartbooks (Workspaces) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
