Date/Time: Wed, 27 Nov 2024 22:39:49 +0000
Account Data Feed is Delayed
View Count: 301
[2023-06-23 16:23:48]
Mark Sear - Posts: 43
Hi there,
I have service package 10 set up which I believe should give me the Denali Live Data feed but I'm getting 15 minute delayed data.
What else do I need to do?
Many thanks
[2023-06-23 21:05:47]
SC Support - Posts: 1895
Hi Mark, please activate the CME Group Exchanges that you want Real-time Data for, you can do that via #3 here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME
[2023-06-26 11:52:38]
I've done that but it's still 10 minutes delayed on the ES/NQ/RTY though it is up to date for Dow and Oil.
[2023-06-26 11:53:38]
Sierra_Chart Engineering - Posts: 17198
The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported Trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
