Date/Time: Wed, 27 Nov 2024 22:29:22 +0000
Position Fill Lines-
View Count: 211
[2023-06-23 16:23:35] |
User357489 - Posts: 72 |
I am wanting to add my position fill lines- theyve worked before and i dont recall changing anything major, the "Use global graphics..." is unchecked. How do i check "Enable" for the position fill lines please?
[2023-06-23 19:35:50] |
Sierra_Chart Engineering - Posts: 17198 |
Not sure what you are referring to but if you want to display chart order fills, refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
