Date/Time: Wed, 27 Nov 2024 22:34:38 +0000
TPO not loading at correct time.
View Count: 247
[2023-06-23 16:20:25]
User012345 - Posts: 2
Hello, I have a TPO that is set to start at market open 22:00, however this only occurs when the software is consistently running. When the software is shutdown and restarted the data is only downloaded from the time the software is started and does not download previous data. all my time and data settings are correct as I don't have issue if the software is running continuously. Can you please see image and advise?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=82664
[2023-06-24 08:33:41]
Sierra_Chart Engineering - Posts: 17198
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
Or, in the case of a Continuous Futures Contract chart, follow these instructions:
After about a minute provide a copy of the Message Log following these instructions:
