Date/Time: Wed, 27 Nov 2024 18:31:00 +0000
Feature Request align transparent text subgraphs vertically
View Count: 417
[2023-06-23 07:41:59] |
User165219 - Posts: 10 |
I'm using text subgraphs to annotate candles above and below the candlesticks. When I set the text subgraph value below the candle to be the low of the candle it displays neatly below the candle. But when I set the text subgraph value above the candle to be the high of the candle it displays over the candle and is unreadable. my work around is to use ticksize and a configurable ratio to vertically offset the text subgraph above the candle, but this is messy and changes for different timescales and scales. Could you guys support a vertical alignment to TOP/BOTTOM for these subgraph texts? or a TRANSPARENT_TEXT_ALIGN_TOP to enable this to work neatly for me? Thanks |
Screenshot 2023-06-22 at 11.34.00.png / V - Attached On 2023-06-23 07:41:48 UTC - Size: 10.77 KB - 88 views |
[2023-06-23 10:04:27] |
Sierra_Chart Engineering - Posts: 17198 |
What is the exact Subgraph Draw Style that you are using?
[2023-06-23 10:06:56] |
DRAWSTYLE_TRANSPARENT_TEXT
[2023-06-29 12:14:07] |
So I guess I'm after a TRANSPARENT_TEXT_ALIGN_BOTTOM instead of TRANSPARENT_TEXT_ALIGN_TOP as the default TRANSPARENT_TEXT is already aligned to the top.
[2023-06-29 13:58:00] |
We are thinking about this.
[2023-07-10 09:04:58] |
In the next release there will be this new draw style: DRAWSTYLE_TRANSPARENT_TEXT_WITH_ALIGNMENT Refer to: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-10 11:46:29] |
Brilliant, I feel honoured to have made an accepted suggestion!
