Date/Time: Wed, 27 Nov 2024 00:38:17 +0000
can i use global data feed.
View Count: 1265
[2014-07-02 18:22:31]
User29458 - Posts: 44
can i use GLOBAL DATA FEED only for data not for trading. if yes please suggest how i can use because of when i try to use then connectivity of chart was gone. so please suggest me.
[2014-07-02 20:07:18]
You can use Global Data Feeds for market data. Only market data is supported with that service. Here are the instructions:
http://www.sierrachart.com/index.php?l=doc/GlobalDataFeeds_India.php#Setup
